CPU Temp is at 44C max load, and MB temp is at 39 max, do I need more cooling?
kman79
When I was planning the build. I planned out to change the two 120mm case fans for some panaflows. 1 exhaust and one intake. But the XP-90 and delta keeps the CPU cool, well relatively, I'm wondering if I still should. I thiink the video card would benefit the most since it' practically blocking aire flow to the upper portion of the case cause it's so long.
What do you guys think?
Those CPU temps look ok to me, but if you think that it will help cool other components in your case, then by all means do it.
