Hi,
I noticed that whenever I set this option to Enabled in the BIOS, the CPU FAN doesn't spin at all, as long as the CPU temperature is lower than 21C. It turns back on when it gets to 21C. As you may guess, this only takes place on cold boots as the CPU temp is above 20C in any other case.
It seems that the board operates the FAN in full speed when it is working, since even if this feature is disabled, the max RPM figure is exactly the same when the feature is enabled and the FAN is on. So it does NOT reduce FAN speed at all, as it only has two modes:
TEMP<21 = FAN off.
TEMP>20 = FAN on at FULL speed.
Is there ANY risk taken when the CPU FAN is NOT spinning at all as long as the temp is lower than 21C?
Have you guys (K8NF-9 owners) set it to Enabled or Disabled?
Thanks.
TEMP<21 = FAN off.
Thanks.
