A aCynic2 Senior member Apr 28, 2007 710 0 0 May 24, 2007 #1 Ok, the manual for my mobo shows an eight pin power connector, but the mobo has a cover over one half and my psu has two connectors. I have a dual core, E6600. Am I supposed to use both connectors or just one (the mobo manual isn't clear on this).
D DaveSimmons Elite Member Aug 12, 2001 40,730 670 126 May 24, 2007 #2 you might get an answer more quickly if you list the motherboard brand and model
A aCynic2 Senior member Apr 28, 2007 710 0 0 May 24, 2007 #3 Mobo: MSI P6N Platinum I didn't think that was as much a factor as the CPU. I'll be glad to get this thing finished.
R Roguestar Diamond Member Aug 29, 2006 6,045 0 0 May 24, 2007 #4 Plug in a 4-pin from the PSU to the motherboard on the uncovered part. Plug everything else in normally. Test.
