I've seen it stated on this forum and elsewhere, that the power consumption of a CPU is proportional to the simple forumla f*V^2, with f the frequency and V the voltage. Is this formula actually accurate, or is it a very crude forula only valid for small changes in frequency or voltage? For instance, AMD's Griffin mobile processor is supposed to be able to lower it's frequency to 1/8 of max (according to an anandtech article). Assuming that the voltage can be lowered by, say, 20% at the same time, this would give a power consumption of only 8% of max.
If this truly is accurate, then I must ask, why hasn't Intel allowed their mobile processors to clock lower? My 1.2 GHz Core 2 Duo (ULV) only goes down to 800 MHz, while a 2 GHz Griffin would be able to go down to 250 MHz. Is there some technical challenge in lowering the multiplier this low, or isn't the power savings potential as large as the simple formula above would indicate (and therefore Intel simply hasn't bothered doing it)?
