b34rhunt3r
I have been overclocking an i5-2500k and under load, the ratio drops from 44x to 40x or lower. I have disabled speedstep as well as c states. Any ideas?
Did you do anything with vdroop? What is your bclk? How did you OC - raise the cpu multiplier, or the turbo multiplier?
llc is at "level 2" in the asrock bios, second highest setting I assume it's 75%
bclk is 100
cpu ratio was raised, turbo is disabled
I really have no idea why the ratio would drop if turbo and speedstep are disabled =/ even if the voltage were dropping, wouldn't it just cause instability?
Sorry, should have been clearer- use coretemp to look at bclk while under stress. It could be dropping.
Else, the CPU might be throttling. What are your temps?
LOLOLOL 😀😀😀
Make sure TURBO is enabled, you can't overclock without turbo.
If you want a static frequency, you can only turn off speedstep. But turbo has to stay on. 😀😀
um I am pretty sure I turned off turbo and raised the multiplier before to oc.LOLOLOL 😀😀😀
um I am pretty sure I tuned off turbo and raised the multiplier before to oc.
My asrock z68 extreme3 was doing this with my 2700k until i changed the Power Draw limit I believe in CPU voltage setting. It defaulted to 100 but i changed it to 200 after searching and seeing similar problems. I saw no more problems with overclocking after that.
The default limit was 150 on my board(z68 pro-3m) so I set it to 200 first and then to 300. Both times the ratio would stay at 44 for about a minute and then drop to 35.
Errr, I can. The multiplier is unlocked...
