I purchased a new mobo last night (IWILL K7S3) to house my new XP2600 (333 FSB). For some reason I can?t set the CPU any higher than the default setting of 100, which runs my CPU at 1.37 Ghz (I believe) and my PC 2100 at 200Mhz. If I try to run the CPU any faster the computer will shut down. I can?t even run it at 133 (XP 2000 speed) without the computer cutting off.
I called the mobo manufacturer and he suggested that it?s either my PS (a crappy 350W PS, but one that has run my XP2000 system faithfully for a year) or my PC 2100 that is to blame. So, what do your guys think? Is the PS the more likely culprit, or the ram... or both? Also, I assume that I NEED PC2700 to run my CPU at it?s proper bus speed as PC2100 only runs at 266 Mhz... am I correct in this
assumption?
I appreciate any help/advice anyone can give.
Thank you.
assumption?
Thank you.
