- May 7, 2012
- 3
- 0
- 0
OK so I just bought a new PC: http://www.consumerreports.org/cro/...overview/asus-essentio-cm6850-01-99045265.htm
And I was downloading my normal system tools when I opened Speccy, which is like CPUID HW:
It read temperatures as follows:
CPU- 35 degrees Celsius
Motherboard- 70-90 degrees celsius (very hot)
CPUID HW read:
SYSTIN-28 degrees celsius
CPUTIN- 88 degrees celsius
AUXTIN- 72 degrees celsius
TMPIN3-36 degrees celsius
So far i am getting different responses depending on program:
So i went into the bios, (which on ASUS's is very easy and you can use a mouse)
BIOS stated the temps as:
CPU: 87.8 Degrees FARENHEIGHT/ 31 degrees Celsius
Motherboard: 73.4 degrees FARENHEIGHT/ 23. Degrees Celsius
The heat sink fan is functioning (its the stock one)
And the other fan towards the rear of the case is also running
I have not noticed any performance lags, i dont think
But i am afraid about the temps, what could be going on and why are the reportings different depending on program?
CPUID HW read:
