CPU monitoring tools
RAiL
21
Can anyone tell me where i can find a program that will tell me the temp of my CPU? thanks
skyjuice
1,462
I beleive "hardware monitor". It shareware and does the trick as long as your mobo has the proper sensing hardware.
Howard
47,982
11
There should be one inside your BIOS (hit Del or whatever key to enter setup at startup). Unless, of course, your motherboard doesn't have a thermal probe near the processor. Most have a case temp probe and a CPU probe.
Goi
6,770
7
Motherboard monitor 4.18, that's what I use...
Try searching for it using a web search engine.
Goi
6,770
7
Hmmn...MBM 5.0 is out, but its still a public beta...guess I'll stick to 4.18 for now.
