Patrick Wolf
So for air coolers. Has anyone experimented with the orientation to see if helps keep the GPU cooler under load? For example, it would seem that this orientation would help pull warm air off the PCB (or backplate) thus keeping the card cooler. The CPU temps may suffer a bit, but the GPU is the one that usually demands the best cooling under heavy gaming loads.
Or does it not make a difference compared to the usual orientation?
