installed a new motherboard cpu for the parents , i3 6300 -stock heat sink- B150-HD3P gigabyte , but the ramping of the cpu heatsink fan is weird.
https://www.youtube.com/watch?v=7bDFP-MdU_k
I found some older post on intel/tomhardware forum stating it is normal but no work around , or that old that the links don't work anymore.
Link down :
So i guess it is normal but any solution I could look into to not have this kind of behaviour?
UPDATE SOLVED : Normal behaviour, no option in bios to change it.
UPDATE 2 : After some Intel account administration/migration problems and vacation they send me a new heatsink for free , a FOXONN updated model instead of NIDEC.
https://www.youtube.com/watch?v=adqcBiwYd80 , and durign stress test around ± 10 C cooler. Smooth post ramp up , better cooling in general and fan speeding up in more logical way when stressing cpu.
Link down :
Tomhardware old answerhttp://www.intel.com/support/processors/sb/CS-033607.htm
The Start up is normal. Please see above URL for more information on this.
I did ran the Intel diagnostic tool successfully and the cpuz stress bench din't go higher than 58C after running it for a couple of minutes.It's just an issue with a certain model of the intel stock fan. I work at an IT distributor which assembles PCs and we have this kind of issue a lot. We have identified at least 3 different models of Intel stock fans and one of them exhibits this behaviour.
We narrowed it down to that particular fan needing more voltage to start spinning. If you had your case open you would see that the fan tries to spin up 2 times before going full speed. I assume that it will need 10V+ to start spinning, and I would guess that the board sends 5V, then 7V and lastly 12V, putting it on full speed.
No need to worry though, your system is fine and everything is in check. If you do not like the "startup acoustics" though you could always install a cheap aftermarket heatsink.
