techiecool
ok, i am trying to build my first pc. i have decided that i will get an amd 1700 and i don't plan to OC. if the FSB is only 266, then will i see a performance increase by getting memory that is over ddr 266 pc 2100.
Originally posted by: ChampionAtTufshop
an easy example to show you waht i mean
100mhz * 10 = 1000mhz (200fsb) => pc1600
133mhz * 7.5 = 1000mhz (266fsb) => pc2100
166mhz * 6 = 1000mhz (333fsb) => pc2700
200mhz * 5 = 1000mhz (400fsb) => pc3200
if its an xp1700+ tbred b, then you should have no problem running it at 166mhz and a lower multiplier to give you the higher fsb (THEN it would be useful to get faster ram as shown above, as you want to keep ram at a 1:1 ratio ..possibly higher, but AT LEAST 1:1)
Now, I don't quite get it... I have Athlon XP 1700+ (the one VERY suitable for overclocking - AXDA 1700 DLT3C 9390257270466 JIUHB 0310 WPMW) which runs 11 x 133 Mhz and DDR memory running at 333 Mhz . Now, I can't change multiplier on CPU (how can I do that?? Schould I have special motherboard or just short some bridges on CPU?? ). All I can do is to change FSB from 133/33 up (134/34, 135/35 and so on, special setting is 166/33).
How can I change the spped of CPU only with memory running it's default speed?
I have Biostar M7VIP motherboard.
In answer to your inquery, you're probably not getting good o/c results because that mobo has very bad o/c options. I doubt that mobo can automatically unlock the clock multiplier on your cpu like recent mobos are able to do. If you really want to keep your CPU FSB at default --( I don't know why you would want 133Mhz FSB paired with 166Mhz FSB of DDR RAM because your system will only perform as good as its slowest component)-- You can manually unlock the clock multiplier of your CPU by modifying the bridges, but I would suggest you get a more recent mobo, because they will automatically unlock the multiplier for you, saving you the trouble, and it will most likely out-perform your Biostar M7VIP.
However, if you are tight on cash, you can manually unlock the cpu pretty easily. By the way, you should overclock your CPU FSB to 166mhz (DDR 333Mhz) making it sync with your (333Mhz DDR RAM) if you can, because that would greatly increase performance. It would be better than just overclocking by the clock multiplier alone.
Hope that helps.
:gift:
