Hi all,
Just completed a build today. Giant red flag when i turned it on: the CPU fan would pitter every few seconds, but never spun up. I shut off the computer immediately and grabbed a big house fan, and started troubleshooting.
I'm using an aftermarket heatsink, so my first troubleshoot was to attach the stock intel heatsink to the cpu fan pins on the mobo, same result. It appears the 4-pin power socket on the mobo is dead.
Right now I'm running the cpu fan through one of the system fan power sockets on the motherboard, and it works alright.
My concern: the fan is only running at 400-600rpm. The AC Freezer Pro 7 is rated at 900-2500rpm. Theres barely any airflow coming out the back i can feel with my hand, certainly mucch less than I felt with my Athlon64 in my older computer.
The 3 case fans work fine, 1 of them I have connected to the motherboard which reads it at 1200 rpm.
Should I be worried about the low cpu rpm? The temperatures are pretty good so far, thats what counts (22C at boot, 27C idle), though I was planning on overclocking. Is it safe to plug in the cpu fan into a system fan socket on the mobo?
System Specs:
FSP 450Watt PSU
Gigabyte P35-DS3L
Intel Core2Duo E4500 w/ AC Freezer pro 7
2 Gigs GSkill DDR2 800
Radeon HD 3850
System Specs:
FSP 450Watt PSU
Gigabyte P35-DS3L
Radeon HD 3850
