CPU fan speed
sisto
I have a Epox 8k7a motherboard with a 1.4 ghz amd processor.
I am also using a drogon orb 3 cpu fan. It is rated to spin at 7000 rpm, howver it is only spinning around 6000 rpm, and as a result the cpu temp is a little higher then expected.
oh- I am used a antec sx1040 case - that has a 400w PS
Anyone got any ideas
1.4 ghz amd
epox 8k7a
512 crucial ram
geforce 2 pro
antec sx1040b
ibm 40 gb 60gxp hard drive
HawkeyeColt
101
Read the specs on the fan itself. 7000 is rated speed +/- 10%. That's just an example. Some are higher than 10% some are lower.
