CPU fan speed controller
inertiat
21
Wondering if anyone can give me a hand.
I'm looking for a manual fan speed controller like this that will work with a Freezer 7 Pro on an ASUS P5N-D. I don't think the Zalman Fan Mate will work because it only has a 3-pin connector (the motherboard connect is a 4-pin) and I'm not sure if the Freezer is too powerful for it or not.
I've tried every piece of software on the internet and nothing seems to slow down my uber-loud Freezer Pro, so I'm resorting to a piece of hardware. I'd actually prefer this over a piece of software because I won't have to wait for Windows to start up to get the speed down, so any help will be very gratefully received. Cake may even be distributed in the event of a breakthrough. No promises.
mpilchfamily
3,559
Any fan controller will do. You'll just have that 4th pin hole on the fan connector hanging off the side. Its the lead that allows the motherboard to adjust the fan speed threw the bios. If your motherboard has the 4 pin header for the CPU fan then you have to make the adjustments in the bios if you can't get any other program to take control of it.
