CPU fan question
TCool
123
Not sure if this is a stupid question or not.
But I purchased a Intel p3 900mhz cpu. It will be put into a slocket adapter.
The place I purchased it from, sent me a fan with it (it was included). But after checking with the manufacturers web page of the fan, the fan is for AMD Thunderbird cpus. Will this fan still fit a P3 cpu? Or are the Thunderbird cpus a different size?
Thanks for any reply.
PS: This is the fan they sent me
http://www.arxusa.com/505008vhz.htm
Demon-Xanth
20,551
Most likely yes. But make sure that on installation the HSF doesn't rock and make sure it is making good contact.
TCool
123
Thanks for the reply. I replied earlier that the fan/heatsink wasn't sitting quite even and thought I would have to get a new fan. But I think I just fixed it... I didn't have the metal heatsink clamp pushed fully all the way in on one side which was causing it to raise up on the other side.
