ok my friend just got a new computer and it kept on hanging after about 15 mins of use, it locked up quicker if playing 3d games and didn't take as long when in windows. so i came over and the cpu fan had been shoved in so hard into the heatsink that it was deformed and the blades of the fan couldn't spin. in the BIOS, it said that the cpu fan was at 0 rpm (obviously) so i took it out and fixed it. now, however, it turns on when you turn on the computer but after about 1-2 mins the fan turns off.
is this a motherboard feature, i heard some mb's will throttle down the cpu fan speed if the cpu is running cool but i've never heard of it throttling down to 0 rpm. is there any way to keep the fan running all the time? i couldn't find it in the BIOS settings so i'm not sure it can be done.
does anyone know what the problem could be?
these are the system specs:
motherboard: Gigabyte GA-7DXE
cpu: Athlon XP 2100+ (fsb is at 100MHz so cpu is running at 1500+ right now)
ram: 256MB DDR
ram: 256MB DDR
