CPU fan noises
canadianboy
I got a P3 700 slot 1 and the fan on it makes some annoying sound.
What causes that noise??
Thanks
fast_eddie
518
It is sometimes is a pre-warning to imminent failure of the fan. Other than 'annoying', what type of sound does the fan make?
zzzz
5,498
may be its coupling the vibrations to the case and the case is rattling. try to put something soft under the case feet.
