Cpu fan making high pitch noise
WraithETC
1,464
Is this a sign that it may fail?
Nothing is touching it to make that sound cept dust minimally.
GalvanizedYankee
6,986
Wow! Too much information! Could you limit your post to three words :D
...Galvanized
Ping to the Pong
217
hahah nice one galvanized. I would say if your fan is making a noise, try spraying it with some canned air and it that doesn't work, its possible that your fan is dying. To be safe, just get a new fan, they are cheap nowadays anyways. Who knows, it could make that high pitched noise forever and not die. When did the high pitch start and how long have you had this fan?
coughtryb
59
fan mechanism could be getting loose...its not unfixable but its not worth your time cause new ones are so cheap anyway. how old is the fan?
