how difficult would it be to set up a LED on your case to show your CPU fan is running... i really havent thought too much about it, but it couldnt be too terribly hard....
The problem with this is that just because a fan is getting +12 volts , doesn't mean that it's actually on. So if you wired the LED in series with the fan, it would always stay on, whether the fan was actually running or not.
Connect it to the speed sense wire from the fan, and it will flash at a rate determined by fan speed. Only problem with this is that it could conceivably get stuck on if the fan jams at the right position.
If you want to do it properly, you'll need a non-retriggerable monostable before the LED.
