The Alpha 8045 is designed for best performance with the fan sucking, and it works very well. If you have a rear case extraction fan near the 8045 it works almost as efficiently as a ducted exhaust system.
A very good reason NOT to use a fan blowing on the 8045 is that it would direct hot air from the heatsink down onto the mobo, chipset and surrounding components.
Hope this helps!
