CPU Fan Header Question
Srotten
17
I just got my ASUS Maximus II Formula motherboard and ran into a glitch. I'm installing the Tuniq CPU Cooler and it only has a 3 pin fan connector. The Asus board has a 4 pin header? Do I need an adaptor cable? Can I just put the 3 pin on the 4 pin header? What is the 4th pin for?
Any help is much appreciated!
-Mark
VirtualLarry
56,571
10,207
You should be able to just plug the 3-pin onto the 4-pin connector. The plastic is keyed so this is possible.
Jul 6, 2008
135
You can also use it on a system fan header that allows voltage control and use a 3rd party such as Speedfan to control it. I do this on P5Q-E. If you do that you may get a cpu fan error when booting but this can be fixed by setting the bios to ignore cpu fan.
DSF
4,902
Originally posted by: Srotten
Thanks Guys,
Anyone know what that fourth pin is for?
-Mark
PWM stands for Pulse Width Modulation by the way. It's a way of controlling the fan speed by cycling the power on and off. The greater the portion of the cycle that's "on", the faster the fan spins.
Srotten
17
Follow-up question. I'm using the Tuniq 120 and the Fan Control in the BIOS doesn't seem to be adjusting fan speed? Is that because it has that external controller (which I didn't hook up because my old Zalman adjusted to BIOS just fine without it). That Tuniq is kinda loud at full speed, any suggestions to get the BIOS to adjust the speed of the CPU fan?
Thanks,
-Mark
