CPU fan for Athlon II Quad
Mar 15, 2003
12,668
103
I don't overclock and never plan on doing so - the stock fan is way too loud of bedroom HTPC use. Any suggestions? I'd like to spend as little as possible, so no funky water cooling set ups :)
mpilchfamily
3,559
Check out whats availible on Newegg. The customer eviews should be able to point out if the coolers your looking at are noise or not. many of them will have the fan's noaise rating either mentioned in the specs or at the web page for the cooler.
hans007
20,212
18
that is odd, the stock fan is a 4pin pwmm , its basically silent . do you have cool and quiet turned on?
manimal
13,559
8
I have been searching for a silent solution for a bedroom htpc for a while, closest I have come in is a scythe mini ninja passive. I use it on a undervolted and underclocked, e8400
What psu are you using? What fans?
