Originally posted by: brucehao
Your HSF should be blowing air into the chip, so that is fine.
Most people think this, but accually this is not the case. If you read on most heatsinks, they are made to have the fan suck air through. Take Alpha for instance, They have a small aluminum shroud covering the heatsink, then the fan sits on top sucking the air through. This gives maximum cooling to the lower fins. Its up to you depending the enviornment.
Here is a quote from alpha:
Which type of fan heat sink is better, "expulsion type" or "induction type"?
According to our tests, the induction type showed better results the the expulsion type. This is because we used an intake cover to draw air through the lower part of the heat sink for more heat dissipation from the lower part of the fins. However, if some other heat source is located near the heat sink, heated air would come into the heat sink and affect the thermal performance, so the choice must be made depending on the environment.
Take a looksee
