- Aug 28, 2012
- 4
- 0
- 0
Hello all and sorry if this is not a motherboard issue, I'm 80% sure and need help. Read a forum topic here (which I can't find) that is a little similar. But more to the point.
CPU fan error (F1) on every boot
Only way to get it to start is to ignore the error (found that help here)
Computer has just been put together today and the speed of the fan is not being recorded by the bios (temp is recording and running fine however).
On a cold boot the fan seems to take a few turns and time (5-8) seconds to
Specs:
Processor: Core i5 2380p 3.1Ghz
Motherboard: Asus P8 Z77- vLX
Ram: 8Gb DDR1600Mhz
Power supply: Be quiet 450W
2 Internal Fans 1 LED 1 Cooling (120mm and 140mm) off the top of my head. (One of these buggers have decided not to work [LED one])
Hard Drive: WD 1.5 TB
Graphics: XFXR7850.
Just to let you know the same problem occurs when only the processor is connected, hence my deductions. However I am not that good at this.
Any help would be appreciated from a Scotsman.
Specs:
Ram: 8Gb DDR1600Mhz
Graphics: XFXR7850.
