CPU Fan Error
CeilingHoles
171
I just built my first computer yesterday, and everything went suprisingly well. The only problem is that sometimes on startup I get a message saying "CPU Fan Error". This usually happens after my computer has been off for a little bit. I'm using an Asus K8N-E MB with an AMD Athlon 64 3000+ (installed with the retail heatsink and fan.)
I started up the PC a few times with the case open to see what was going on with the fan. One time when I got the error message the fan had stopped and I shut my pc right away. Another time I got the message but the fan was still going.. How can I resolve this issue? Thanks
LTC8K6
28,520
1,576
Sounds like you need a new fan. Perhaps the RPM sense is not working properly, or the fan is actually stopping intermittently.
CeilingHoles
171
Asus tech support is really crappy. I waited for 35 minutes to talk to tech support.then they asked for my number to return my call later...they never called back. that's BS
NeoPTLD
2,544
I've something like that on my board, but I disabled it. It caused problems
