CPU Fan drives me crazy! Not natural!
adamone11
105
Hi, I just made some new installs to my system, and then, 2 days later the fan on top of the heatsink started making a really annoying sound, almost like your CD-ROM drive was stalling. I opened 'er up, and dusted it off. When it slows down a little it stops making the sound. I think it's rocking back and forth, but I don't know how to fix it. I'm thinking of cleaning it more in depth so the fan blades are balanced. Right now, I have my microtower (mATX) tipped over on its side--pretty hilarious, but the noise is gone.
Oh, another thing: this really shouldn't be a problem (it's a pretty large leap) but my ps is only 90 watts, and I have a 500mhz k6/2, a 30gb 75GXP, an 8gb 5200 Maxtor, 2 sticks of 128 mb pc100 cl3 ram, a CD-R, a CD-ROM drive, a 3com 3c905btx-nm PCI card, and integrated 4mb Rage Pro, integrated sound. I'm thinking I may be taxing the ps a little, but the sound doesn't just stop when the HDD's power down. Plus, since I don't want to blow anymore money on a new ps (mATX at that) for this piece of junk, replacing the ps is not an option.
Anyone think a simple new fan would be the solution? I removed it and the fan was kinda loosely attached to the motor at first; it could wobble, and indeed, I think that's part of the problem. I'd rather not send it back to IBM (still under warranty though...) because of shipping maybe or other complications. I bought it through bestbuy, so you'd think I could call them up... Anyone know the kind of hassle I'd have to go through to get a new fan from bestbuy if my comp was still under warranty?
I live in Dallas, TX (UNT), and might be willing to trade a stick of 64mb ram for a new fan if it works and is semi-quality.
Thanks,
Adamone11
dowxp
4,568
the power spply should be fine. but, just complain to best buy and they'll refund it.
adamone11
105
errr... I bought the system through bestbuy. The only warranty that still applies comes from bestbuy, and the fan has a still barcode on it (like everything else inside). They won't need me to send it in for testing or confirmation that it's bad, right?
mstudd
425
I had a similar problem with a K62-500 fan in a friends computer.
I just bought a cheap Coolermaster heatsink and fan and fitted it with some thermal paste.
You can buy these heatsinks for next to nothing and it will save you all the warranty hassles.
larrymoencurly
598
I had that happen with the Delta fans that AMD provided with retail boxed K6-2/500s. AMD sent new fans, but then I found that peeling up the label and applying a drop of 3-in-1 oil also worked. But almost all the Deltas vibrated badly.
