- Jul 29, 2005
- 22
- 0
- 0
I use Abit EQ to monitor my cpu/case temps. My case temps are usually in the low 30's and my cpu WAS in the 30's in the winter time. Now that its summer my cpu temps go all the way up to 49.5 under load. My questions is, is it better to have the cpu fan blowing air ONTO the cpu or pulling the heat away? I have a tornado fan currently on the CPU and anyone wondering if it is loud... YES VERY!! Also my current fan set up is i have 2 front fans blowing air in 2 rear blowing out for exhaust, i also have one more fan slot on the side of the case, do you think putting a fan there would lower temps?
