I'll soon be building a new rig (AMD AM3) and plan on overclocking a bit. I will be dealing with my first non stock cpu cooler. I was about to order Xigmatec Dark Knight. http://www.newegg.com/Product/Produc...82E16835233029
Correct me if I'm wrong but I think that is configured to only blow up or down. If I have a top mounted PSU, will it be a problem if the CPU fan blows up into the bottom PSU intake fan? I would think I wouldn't want to add more heat the PSU.
On the case I have a rear exhaust (just below the PSU) and a top exhaust (just in front of the PSU). Also 2 front mount cool air input fans.
Would it matter if I use cpu fan that blows back to the rear exhaust or is the upward fan going to be ok?
Thanks
Thanks
