ok this has been eating me away all morning.
I have a gigabyte 965p ds3, a conroe 6400 with stock fan on it. im using F4c bios.
after the system has been off awhile, when i power it up the CPU fan hangs, it will start, then stop, then start, etc. after 10 seconds it sometimes is fine. other times it keeps going and will periodically stop for a second after 3-4 minutes. Now it has been running a few hours , like its warmed up ...
im getting like 35-40 C on the cpu temp and 44 on the system temp. the fans are idling at 800-900 RPM though. is that normal? i have the cpu fan speeds set on auto in the bios by default. I know there are several options to manually adjust but i havent played with those.
gigabyte packaged the I-COOL tool that you can check temps etc out from windows. when i load this, my CPU fan just completly shuts off, and as soon as i close the program it starts again.
I was thinking the fan was just bad, but whats the link between all of this =X
