CPU Exchange and Flash Player compatibility help
FrankRamiro
Hi guys; toshiba AMD C50 1GHZ Processor c655D-S5202 with win7
I'm trying to download Flash Player to Stream from ESPN3 it sends to adobe site to download Flash player 15 but it wont download for what i understand need higher CPU processor and i try to download a older version but it always send me to the flash version 15,
how can i get a version of flash that can run on ESPN3.
Also i have Google chrome browser it runs but i can't open full screen.
Also i have here in my scrap a toshiba L355D-S 7901 with AMD Turion X2 dual Core 2.3ghz cpu
my question can i swap the cpu from the AMD Turion x2 2.3ghz to the AMD C-50 1.0ghz cpu?
http://cpuboss.com/cpus/AMD-Turion-X...82-vs-AMD-C-50
The problem is that ESPN requires a certain version of Flash to work, so just rolling back Flash isn't a guaranteed solution. I bet you can't change the CPU. I would try updating your GPU drivers and see if it works. That GPU should handle a little decode for you.
