- Dec 2, 2003
- 14
- 0
- 0
Hello all,
A couple of questions from a newb that despite a few searches I could not find answered. I apologize if these questions are common and I just missed them.
Preface:
I recently built a new computer. This system is as follows:
CPU: Intel i5 2500k
MB: MSI P67A-G45
RAM: G.Skill 6GB (3 x 2GB) PC 1600 (PC3 12800) F3-12800CL9T-6GBNQ
VC: ATI Radeon HD 6950 2GB
Case: Antec 300
Q1)
Yesterday my new cooler came in to replace the stock cooler. I have purchased the Cooler Master Hyper N520 and I installed it using the Arctic cooler directions for thermal paste application, with a thin vertical line of thermal paste after having cleaned both the CPU and the Heatsink with 91% Alcohol.
After installing it, I ran OC genie II (MSI's auto overclocker) and after rebooting, it settled on a 4.2 Ghz clock.
I then ran RealTemp and Prime95 to check the temps both at idle and full load.
During testing, I noticed that there was an ~4-5 degree difference (Celsius) between Core 0 and core 1 (with core 0 being cooler), Core 1 and 2 were about the same, and there was an ~3-4 degree difference between Core 2 and 3 (with core 3 being warmer).
Basically it looked something like this:
Proc. Idle Load
CPU0: 28C 59C
CPU1: 32C 63C
CPU2: 31C 63C
CPU3: 35C 66C
Is this normal/ok? Or is this indicative of an incorrectly installed CPU cooler?
Q2)
After OCII overclocked the system, for some reason it raised the DRAMM Voltage to 1.65v, but seemed to keep my memory at 1333 rather than raising it to 1600. It is my understanding (after reading all the great threads about OCing Sandy Bridge) that you want to keep the DRAMM Voltage below 1.65v, (despite what they seem to say here: http://www.bit-tech.net/hardware/cpus/2011/01/07/how-to-overclock-the-intel-core-i5-2500k/5 ) and so I manually lowered it to 1.55v. Is this ok? And if not what should I set it at?
And finally can I run my memory at 1600 (since it is rated at that speed) at 1.55v rather than 1.65v? I checked Newegg's listing of the ram and it says that its voltage ratings are 1.5-1.65v. Does that mean it runs at 1.5v when underclocked and 1.65v at 1600, or does that mean that it is safe to run it at 1600 and 1.5v?
Thank you for the help, and if I left anything out let me know and I will try my best to answer.
Preface:
CPU: Intel i5 2500k
MB: MSI P67A-G45
Case: Antec 300
Q1)
Proc. Idle Load
CPU0: 28C 59C
CPU1: 32C 63C
CPU2: 31C 63C
CPU3: 35C 66C
Q2)
