stock CPU FANS run the CPU's hotter than I would like at idle (cpu1) 127 and (cpu2) 123 degrees respectively. They have not failed yet though. Suggestions on fans that would be the same size but with better performance. NO WATER COOLING PLEASE. UPDATE: I moved the case around for better air flow and took off the cover. I managed to get it down 10 degrees for both CPUs
Thanks
Thanks
