Question CPU cooler in a closed case
iCyborg
1,350
62
I'm finally replacing my ancient PC, I've been waiting for it to die, but starting to lose patience.
I'm eyeing 9950X3D and leaning towards Fractal Define R5 or R7 case with its closed panels option.
My concern is CPU cooler, never used AIO and my question is "does it make sense to put fans at the top if the case's top will be a solid panel and not a mesh"?
Same goes for front. The final alternative is at the bottom where I don't mind the mesh, but I've read it's not the best for pump durability.
Would a good air cooler be sufficient for 9950X3D in a closed case and no OC?
I don't plan to use 4090/5090 GPU or something with exorbitant power, 9070XT at the most, maybe even 9070 vanilla to further help with keeping heat down.
In2Photos
2,532
2,755
What is the reason for opting for the closed panels? There are plenty of air coolers that would work well with the 9950X3D. Check out the Zen 5 build thread in the CPU section. Several users are on air in there like @Markfw.
Markfw
May 16, 2002
27,186
16,077
Personally, case fans are good, but in most cases, and open side panel allows all fans to blow on their respective targets, but the open panel allows for maximum exit of the hot air.
Yes servers are closed, but their case fans are ungodly noisy an require AC air temps to be in the inbound air.
BonzaiDuck
16,529
1,971
There are enough good heatpipe (air) coolers that come within < 10C of AiO water coolers, and there may be one or two that prove better than that. That is, the load temperatures for OC'd processors prove the performance, and you can find those results in data provided in comparison cooler reviews.
The only stipulation is that you can count on needing a midtower case and it probably needs to accommodate a cooler up to 158mm to 160mm high from bottom of its base. So left case panel must close without obstruction when the cooler is installed on the motherboard. There may be "shorter" air-coolers -- you can seek that out with a search of your own. The ThermalRight Phantom Spirit 120 EVO rates among the best. Another ThermalRight model, the Royal Pretor 130, edges out the Phantom Spirit in review comparisons, but it is bundled with fans of non-standard sizes. Some noobies may have had confusions while installing it (or attempting to install it!). Check the spec heights on those models, but they shouldn't present any problems fitting in the cases.
I was able recently to find a brand new ThermalRight Le Grand Macho RT shipped from some outfit in Spain. It's still good for LGA 1851 -- last year's Arrow Lake processors. I would suppose it, too, would work with your AMD Ryzen 9. "TechInn" I think is the reseller's name -- they were online last month -- TechInn under TradeInn's umbrella. Here's the link for Le Grand Macho RT, because they still have it, priced the same as previously.
Reactions: iCyborg
iCyborg
1,350
62
To minimize both noise and rgb lighting - I'll take nonrgb over rgb, but it can be hard to avoid these days. I'd rather downgrade to 9900X if need be, tbh 9950 is likely an overkill, I'm not a heavy gamer or anything.
Thanks. I remember Markfw mentioning ThermalRight Peerless Assassin, didn't know about Pretor 130, looks good too, I'll pick one of these two, both are quite cheap.
Define 7 XL is too big, it would look awkward next to my desk, Define 7 is as large as I want to go. I'm not particularly limited by budget, more by space.
Wondering how people cool those 300+ W TDP Threadrippers? Do their physically larger packages make it easier to dissipate heat? Or people just accept jet noise?
BonzaiDuck
16,529
1,971
Design 7 may be a perfectly good case. I myself recycle CoolerMaster Stacker 830's first released around 2007. I have a formula of fan deployment and cooling that I've used in two of those cases so far. I have a third one awaiting a new build.
Noctua has a line of "industrial" grade fans, or with "iPPC" in the model name. I think they have a 3,000 rpm 120 and 140 iPPC, and I always need at least one of those for a build with a heatpipe cooler -- maybe two. But a motherboard-controlled iPPC-3000 should not be a noise annoyance.
300+W is a toasty TDP. The coolers I linked are more than capable of handling 250 to 280W. You might want to revisit the idea of an AiO, but check the capacity thermal wattage for those.
18,892
Ask Markfw for one of his older Epyc chips. They are absolute beauties. Super smooth in Windows daily usage plus the increased surface area of their IHS allows even 280W to be cooled almost silently. I have his previous 128 thread Zen 2 chip. I was using it just the other day and man, it's always nice enjoying seeing tons of cores at work in Task Manager and gobs of RAM bandwidth available so you know for sure that your CPU isn't starved for anything and giving you the best performance.
You could run the 9900X or 9950X3D with DDR5-6000 or 6400 but that's still less than 8000 MT/s that these CPUs really need in heavy multicore workloads to perform optimally. There are rumors that next year AMD will be releasing Zen 5 consumer CPUs with an updated IOD to handle CUDIMMs and speeds beyond 8000 MT/s. I personally would feel pretty pissed if they did that because I spent a lot on my 9950X3D and for me to not have native CUDIMM support because AMD was lazy is going to make me inconsolable.
But if your primary use case is gaming, then DDR5-6000 CL28 is good enough for you and 9900X3D should give you decent performance for both applications and games.
18,892
Depends on the cooler. There are nasty ones with jet noise but also great ones from Arctic Freezer that are virtually silent.
Quintessa
102
Nope. If the top is closed, you’re basically blowing into a wall. Airflow needs a path. R5/R7 are designed with that in mind, front intake (behind the solid door, still has side vents), rear exhaust. Top fans only help if you remove the ModuVent covers.
Yeah, a big dual-tower air cooler is enough for a 9950X3D at stock. You’ll cap out around ~120W package power under heavy load, which is trivial for those coolers even in a Define chassis.
For your GPU choice (9070 XT or below), case thermals will be totally manageable with just a couple front intakes + rear exhaust. Stick with air and enjoy the silence.
Paperdoc
2,478
365
Regarding the LIGHTS concern, even if you cannot avoid getting some in a component, there are simple ways NOT to have them working. Most such devices now have separate lighting connection cables that go to a controller or a lighting header on the mobo. Simply do not connect. Some devices have lights and their own controller built in and are controlled by digital communication with an app running in the background, using a USB2 cable connection to the mobo. Because that app also controls other aspects in some cases, you cannot simply not run it. But normally you CAN use the app to turn the lights off permanently.
iCyborg
1,350
62
Got it guys, air cooler it is.
As for Threadrippers, it was a rhetoric question, I'm not seriously contemplating those, though 4/8-channel memory is appealing.
It's just that in most reviews the best coolers top at 250-260W heat dissipation, so wondering what the heck is used for those 300+ W beasts.
Needing to install SW to control lighting is another pet peeve I had with my mouse that I'd like to avoid if I can lol.
