retab12332
For i7 9700K, no overclocking, how is this cpu cooler for it, COOLER MASTER HYPER 212? What specs of the cooler do I need to look at?
May I ask what specs of a cpu cooler do I need to seek when matching it to a CPU? And also, the COOLER MASTER HYPER 212, is it like okay-ish or not good?You can get by with a budget cooler if you don't intend to overclock. I would suggest this one as an alternative:
Amazon.com: DEEPCOOL GAMMAXX400 V2 Blue CPU Air Cooler with 4 Heatpipes, 120mm PWM Fan and Blue LED for Intel/AMD CPUs (AM4 Compatible): Industrial & Scientific
Buy DEEPCOOL GAMMAXX400 V2 Blue CPU Air Cooler with 4 Heatpipes, 120mm PWM Fan and Blue LED for Intel/AMD CPUs (AM4 Compatible): CPU Cooling Fans - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
It's the Deepcool Gammax 400. Very similar to the Hyper 212, but with a more powerful fan, so a bit more cooling headroom if you need it, for less money.
IMO this is probably the best bang/buck cooler out there. I recently picked one up for a future build after a fair bit of research.
You really have to spend a LOT more money and get a significantly larger cooler to beat this one.
I could be off or mistaken, but Intel seems to top out its spec wattages at around 125W. Lesser chips could run at 95W peak. Someone said in a forum the other day that the were planning to build something with 35 to 65W peak thermal output. [What is the name of that spec? I'm having trouble with my memory lately.]Specs are all but useless for matching coolers to CPUs as there are no actual standards for watts produced or cooled. Your best bet is read many reviews.
Hyper 212 was a good cooler from MANY years ago, that offered good performance for the price back then.
Today it coasts on that past reputation and is not a good value.
You can get by with the Hyper 212. If you already have one, use it.
But why buy a cooler that costs more and performs worse than the Gammaxx 400. If interested in this class of cooler, the Gammaxx is the better/cheaper option.
Read Anandtech's10700 vs 10700k review, as well as the various articles linked in it. Your information is out of date. Of course, even the included stock cooler for the 10700 works, because the CPU will thermal throttle to protect itself.I could be off or mistaken, but Intel seems to top out its spec wattages at around 125W. Lesser chips could run at 95W peak.
Thanks for the reference. I found the article right away -- dated 21st of this month. Now I can see that I might want to build a Comet Lake next year. [Yes, I remember now -- the spec is called "TDP" or Thermal Design Power.]Read Anandtech's10700 vs 10700k review, as well as the various articles linked in it. Your information is out of date. Of course, even the included stock cooler for the 10700 works, because the CPU will thermal throttle to protect itself.
