So it seems that my CPU cooler seems to be stopping according to CPUID HW monitor. It seemed that when my core went from .98volts under power saving up to 1.34 volts under load that it happened. I had a random freeze earlier, then I noticed that the fan had problems. Its an AMD phenom II 955 BE, 3.2ghz. How would I troubleshoot this? NOTHING in BIOS is changed, from a ga-ma770t-ud3p gigabyte mobo.
It keeps doing it...I know its not supposed to happen, just started today, has run a few days fine. Suggestions? Just keep an eye on it? Its the stock cooler BTW nothing OC'd, nothing in the BIOS at all changed.
