Question CPU cooler be horizontal or vertical ?
retab12332
77
Should the airflow be going from bottom to top, or front to back of the case ? Cooler is Be-Quiet! Dark Rock Pro 4
Space Tyrant
149
115
I would argue that both are right. From bottom front to top back should normally be the main flow. In my situation, with the computer inside a desk cubby, it's even more important. :p
edit: I'm not how sure your title matches your question though.
amrnuke
1,181
1,772
As @Kenmitch said, front to back.
Depends on the case, but most commonly, front-to-back works best because there is typically a rear exhaust fan near the top of the back of the case. Installing the CPU cooler bottom to top in such a case would make airflow more turbulent, reducing cooler performance.
That changes for instance if you have a case with bottom intake fans, front intake fans, top exhaust fan(s), rear exhaust fan, in which case you could probably put the CPU cooler in whatever direction you wish!
Reactions: retab12332
retab12332
77
No top nor bottom fans, just 1 mid-positioned front, 1 top-positioned back.
WilliamM2
2,850
809
What cooler is it? My Mugen 5 can only be mounted with air flowing front to back. I suppose I could put the fan on the other side for back to front, but no way to get bottom to top air flow.
