- Jun 18, 2004
- 196
- 0
- 0
I did a minor upgrade to one of my machines. Upgraded the Atholn 1ghz to an AMD Palomino 2000+. The motherboard is an Asus A7V133-c which can support this processor with the board revision # and the Bios that I am using. Got it running at 1667 mhz, but when installing a program I got some memory errors. Ran memtest and got all sorts of errors on test 5 running my PC133 SDRAM at 133mhz. I backed down the system to 1250 mhz which is one of the default settings and then started moving up the FSB/Memory settings to just before where I would get errors. Ran fine for a while, then had occasional hang at startup.
Today, it hung at startup and when I restarted I would not post. After checking all of my connections and resetting the CMOS I finally changed the processor back to the Athlon 1000 and it started right up.
Set the ram speed at 133, the FSB at 100 and the processor at 1000. Runs memtest fine where the other processor caused errors.
It seems pretty evident that the processor was causing these problems or at least is a major factor contributing to the problems..
I just want to confirm that a processor could cause these types of memory problems and the processor I bought 3 weeks ago is the problem.
