New motherboard. Old case, CPU, heatsink/fan and case fan. Both fans worked correctly under the old motherboard -- usually totally silent. Along comes my new Biostar P4VMA-M and new power supply, and all the fans run full speed constantly.
The power supply fans aren't the noisemakers, and as far as I can tell, are running as they should. The CPU fan, however, stays around 5,000 RPM. The case fan stays around 2,000.
These fans continue running after I put the computer into standby.
I've tried to regulate them using Speedfan. The application has no effect.
The BIOS seems to have no mechanism for fan-speed control. It only shows me how fast they are running.
And, finally, my CPU temperature stays around 30C when idle and gets to about 38C under a heavy load. These seem far from hot to me. I'm running a Socket 478 Celeron D 325.
So, do any of you forum members have suggestions? I installed the motherboard myself -- a first -- and suspect I might have done something wrong. However, the rest of the system seems to be working fine.
Thanks in advance.
Thanks in advance.
