Question cpu and motherboard combos - please help-
ripo66
Hello friends
I have a number of motherboards And number of processors (attachd in the list below)
I want to assemble and build from the list 3 computers I would be happy if you could please help me with the the right and strongest combination
number one 1 will be The most powerful (cpu and motherboard)
and so on ....
2nd place
3rd place
By the way I am aware that the hardware is very old 🙂
CPU:
E7500 CORE 2 DUE
E4600 CORE 2 DUE
E2160 PENTIUM
E5400 PENTIUM
E8400 CORE 2 DUE
E5200 PENTIUM
E7400 CORE 2 DUE
E5700 PENTIUM
E2140 PENTIUM
E7200 CORE 2 DUE
Q6600 CORE 2 QUAD
E6750 CORE 2 DUE
motherboard:
INTEL DG41WV
INTEL DG41TY
INTEL DG31PR
INTEL D945GNT
INTEL DQ965GF
INTEL D945GCNL
INTEL D102GGC2
INTEL DP35DP
ASUS -P5KPL-AM
ASUS P5LD2-SE
ACER -EG31M
MSI 7346 -MS P-6-N SLI V2
GIGABYTE GA-P35-DS4
GIGABYTE GA-945GCMX-S2
GIGABYTE GA-P31-DS3L
GIGABYTE GA-G31M-S2L
GIGABYTE GA EP-43UD3L
Thanks in advance everyone
I can tell you which would be the fastest CPUs of the lot.
Q6600
E8400
E7500
Though the bus speed on the E7500 is actually lower than stuff like the E6750, which is bad in some ways.
Not gonna spend any time trying to figure out which boards can host those CPUs, though. You should be able to find some compatibility lists somewhere.
GIGABYTE GA-P35-DS4
These are your best boards. I would put the Q6600 in the P35, or possibly the EP-43, depending on which one has the better / higher-spec VRMs.
The other board, use for the E8400, and put the E7500 into the G31M board (bonus, use the iGPU).
are you sure this is are the best boards ?
for example the chipset on the
GIGABYTE GA-P35-DS4
and
is better than the
GIGABYTE GA EP-43UD3L ? or the INTEL DG41TY ?
and i think that E6750 is better that the e7500 fix me if i wrong
@ripo66
E6750 has more L2 and faster FSB speed, but E7500 has a higher clock. I would only use the E6750 if you were prepared to overclock it to ~3 GHz to make up for the clockspeed deficit. You can probably do that at stock volts though.
