CPU 120mm Fan Question
ManusDei
7
So for my case i bought a 120mm fan for side cooling. But i decided to go with a 200mm side cooling fan that is compatible with my case instead so i had the 120mm to play around with. The fan is an Antec 120mm Red LED Case Fan (Specs for the 120mm Antec listed below).
My question is, can i use this on my Cooling Master Hyper 212 EVO as a 2nd "push" fan. The EVO comes with adapters so that i can just slide it over the heatsink just like the fan that was included with the EVO. I plan on running it using my NZXT Sentry Mesh fan controller and leaving it set on the highest speed setting on the adjustable slider included with the Antec. Will using this Antec "Case" fan present any problems (i cant think of any, but it is listed as a "case" fan and is LED so i just want to make sure)? Thanks for any help in advance....
Antec Model
761345-75026-4
Spec Type
Case Fan
Compatibility
Case
Fan Size
120mm
RPM
1200 / 1600 / 2000 RPM
Air Flow
39 / 56 / 79 CFM
Noise Level
25 / 28 / 30 dBA
Power Connector
3 / 4 Pin
Color
Transparent LED Red
Physical Spec
Dimensions
120 x 120 x 25mm
Features
3-speed switch lets you balance quiet performance with maximum cooling
3-pin and 4-pin power connectors provide convenient connections to your motherboard or power supply
Fan-speed monitoring capability included (requires compatible motherboard)
System Specs:
-EVGA SuperClocked 012-P3-1573-KR GeForce GTX 570 HD w/Display-Port (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
- GIGABYTE GA-Z68XP-UD3P LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
- Western Digital Caviar Black WD1001FALS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive - OEM
- CORSAIR Professional Series HX650 (CMPSU-650HX) 650W ATX12V v2.2 / EPS12V 2.91 SLI Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply
- Crucial M4 CT064M4SSD2 2.5" 64GB SATA III MLC Internal Solid State Drive (SSD)
- COOLER MASTER HAF 922 RC-922M-KKN1-GP Black Steel + Plastic and Mesh Bezel ATX Mid Tower Computer Case
-G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL (9-9-9-24-2N; 1.5V)
-COOLER MASTER Hyper 212 EVO RR-212E-20PK-R2 Continuous Direct Contact 120mm Sleeve CPU Cooler Compatible
-3 [200mm] fans (side, front, top) & 1 [120mm] rear fan; 2 [120mm] push/pull heatsink fans
-ASUS 24X DVD Burner - Bulk 24X OEM
-Intel i5 2500k 3.3 GHz 6MB Cache CPU
tangrisser
27
I don't see why it could cause any problem.
Just make sure you've properly install it on the heatsink and connect it to a fan header.
BFG10K
22,709
3,008
That’s an Antec tri-cool fan. It’ll work fine, though the LED may possibly dim if the fan controller reduces fan speed by reducing the voltage.
ManusDei
7
I have noticed that when i turn down the fan speed on my controller it dims the LED. Not too worried about that though. Glad to hear its not a problem. Felt kind of ridiculous posting this, because i couldn't think of any real reason the fan wouldn't work, but just wanted to make sure. Thanks for the replies....
Elcs
6,278
Like the famous saying, measure twice cut once...
Best to be knowledgable before making the purchase :)
Zardnok
670
Actually, I think it might be a problem if I am understanding your situation.
The EVO comes with one push fan and one pull fan already for >fan>HS>fan> and if I understand you are adding the case fan to also push, so you have >fan>fan>HS>fan> with two fans back to back pushing. If that is the case, the airflow from the first fan will affect the airflow into the second fan in line causing it to spin irregularly and the rear exhaust fan will have more airflow into it than it currently exhausts which would also cause it to spin irregularly. The EVO design works because there is equal air in as there is out, adding a 3rd fan could cause irregular blade spins and greatly reduced fan life.
ManusDei
7
The EVO instructions discuss installing a push/pull configuration and does not discourage this. I am not sure that it would truly affect fan life to the extent i should be concerned with it. And if so, i will take several degrees cooler versus some reduced fan life (they are cheap anyways, processors and other components aren't).
