Coupler for Cat5e. Will I notice problems?
RC7
521
Ok, I have to drive upto philly today to network my sister's and her roommate's computer. They want to go with a cross over cable because it cheaper than a hub (atleast at any B&M store). Problem is, staples only carries a 10ft crossover; they need atleast 30. I was planning on coupling the crossover with a regular patch cable. Would they notice any speed problems, or worse?
ojai00
3,291
i'm not sure if you can couple crossover cables or not. i currently use 2 couplers to network my 2 computers at home, but they are going into a router. i dont really notice any speed differences, but i have never tested. good luck.
RC7
521
I read on a different post that it was ok to couple a crossover with a patch. If you don't notice any issues with the coupler, they sure won't ^_-. Seems to be the best last minute solution. If i had gotten around to ordering a cable i coulda got a 50ft one for the price of a 10ft at staples, oh well.
ScottMac
Moderator<br>Networking<br>Elite member
Mar 19, 2001
5,471
TO my knowledge, there are no Cat5e rated couplers. There are Cat5 rated couplers, and they would be jus' fine for 100 meg Ethernet. If you buy an unlabled / unrated coupler, chances are it's not a Cat 5 capable device, and may degrade performance.
Check Radio Shack, CompUSA, Circuit City, or many electrical/electronic parts supply stores. I think they have rated couplers. They may also have longer jumpers (straight through and crosover).
Good Luck
Scott
RC7
521
I called radio shack last night, and asked for a cat5 coupler. They said they had it, so I assume it should work out ok.
nightowl
1,935
BlackBox carries Cat5(e) rated couplers. They run about $15 though, but they do exist.
Eltano1
1,897
If a coupler cost $15.00, why no put $5.00 more and go for a hub. I think that it will be a better setup.
Best regards
Eltano
