anthony88guy
Everything went smooth as butter. Just had a few questions since I?m a newbie.
1. I have all my fans hooked up together on one Molex line; at the end I have my SATA II HDD. Is this a bad idea, should I run it on its own power line?
2. Could someone recommend program that I could use to "torture" my system and find any errors, not that I have had any so far.
3. I?m really new to XP since I've been using windows 98SE for some time now. I bought Windows XP PRO, but when the computer boots up the splash screen shows Windows XP. Not that it?s an issue cause under system info it shows Windows XP PRO SP2.
thanks
thanks
