- Jul 11, 2001
- 41,210
- 10,393
- 136
Over Thanksgiving I took some shots of family, not a ton. I was occasionally having a look at them on the camera's LCD, the camera a P&S Canon 100HS ELPH. All of a sudden after a few days, when I went to look at the shots I'd just taken I got an error for each of the shots I'd taken over the last few days saying Unidentified Image. Folders (the camera creates a new folder for each day of shooting) from weeks/months before appeared unaffected, I could still see those, it was just the recent ones with this problem. When I removed the card (64GB SDXC) to a PC the problem folders appeared empty. People suggested I run photo retrieval software and I downloaded and installed a couple of freebies which took many hours to run but I couldn't see anything retrieved. I still have the card, haven't done anything with it.
Now, my habit was to remove the card to a USB card reader and insert in a PC and copy pictures or folders to a PC or my NAS and then reinsert in the camera.
Someone said this is not regarded as good practice and I should reformat the card after doing these maneuvers.
Well, this is doable, but I'm not sure it's all I should do here or if I should really be adopting this practice.
I don't trust that 64GB SDXC card now, would you? Yes, I can test it somehow, I suppose, but for the time being I've put a 16GB SDHC card in the camera, took it from my Pentax K-x DSLR. I bought another card for that DSLR, just unpacked it, it's the largest card the camera supports, a 32GB SDHC.
1. Should I reformat that 32GB SDHC card in the Pentax DSLR before using it?
2. Should I make a practice from here on out of connecting the cameras to a PC in my network by a cable and copying folders/pictures instead of removing the card to a card reader, either USB or in the case of one of my PC's, in the machine's integrated card reader?
Comments/suggestions/advice/wisdom appreciated!
