- Aug 6, 2001
- 77
- 0
- 0
1) How much of a difference will it make when Intel moves to dual channel DDR versus current boards? I've read that Intel is planning on releasing a dual channel DDR board at the end of the year or early next year. Will dual channel DDR be able to out-perform rambus boards running at the same fsb?
2) Is there any significant performance gap between the newest chipsets (845G, SiS 648) and the slightly older chips (845D, SiS 645)? In other words, if you were to change from an older chipset to a newer board would you be able to notice the difference?
Thanks.
Thanks.
