I recently built an Athlon XP 2100+ system on a Chaintech 7VJL Apogee Deluxe MB.
I had some stability problems initially with the system, random reboots and BSOD. Usually during memory intensive operations, SiSandra ... 3dmark etc.
The problem seems to have gone away for the most part,since raising the vdimm voltage to 2.8.
The thing I am noticing now is some stability problems when using CPU intensive operations, using MBM5 in notice the cpu temp rising quickly when pushed.
The normal idle temp is 49c but I can watch it move past 55c very quickly when using the CPU.
I think my fist mistake was using the heat compound that came with the CPU, I was told to remove this stuff and use some Artic silver.
I also have 3 pathetic noname case fans which I will be replacing with Thermaltake A1357 Smart DC Case Fan II .
I am hoping this might solve the problems, Any advice on what I may be missing ?
Also if anyone out there is uing this same board. I am unable to activate the onboard game port, bios shows it as disabled and does not have an
enable setting. I looked over the board, and in the manual and no jumpers are shown to change this.
Any suggestions ?
Thanks in advance
Any suggestions ?
Thanks in advance
