couple basic dos questions
NleahciM
242
Hey - so I need to do some things in "dos" on a computer running windows xp pro sp2. So mostly right now I have two problems:
1. how do I change to a directory with a space in it's name? I'm trying to switch to c:/program files. Can't figure out how...
2. How do I make a shortcut for something to run in dos? So that when it finishes running, the command window will stay up so that I can read the output?
Thanks for your help!
KLin
30,951
1,079
1. either cd progra~1 or cd "program files"
2. Can you elaborate a little on what you mean?
NleahciM
242
A ha! I had tried program~1 - but I couldn't remember how many letters dos names were shortened to. I had also already tried the one with the quotation marks but it didn't work :( but pgora~1 did!
What I mean about the shortcut is that some programs when you run them in dos will quickly say write something and then finish, bringing you back to the dos prompt. But if you just make a shortcut to a program like this, it will run in dos, then the entire dos window will close, thus you can't see any output from the program after it has finished. To get around this I simply open up a dos prompt and find the correct program and run it from dos that way - but that's just kind of a pain...
kamper
5,513
The typical solution is to add a read statement at the end of your program so that it will not exit until the user hits enter.
EagleKeeper
Discussion Club Moderator<br>Elite Member
Staff member
Oct 30, 2000
42,589
Set up a batch file to run the program.
Put an input statement after the execution statement.
You may also be able to set the properties of the shortcut to not close on exit.
MrChad
13,507
Just wanted to point out that it's not DOS, it's the Command Line Interface (CLI). While Windows 9x included DOS, Windows NT/2000/XP do not.
Modeps
17,254
44
:thumbsup:
NleahciM
242
Hence why I quoted "dos" in my original post :)
SonicIce
4,771
Hey, I have a question too! When I run a program from a BAT file, the program opens but the prompt stays open and I have to alt-tab and close it then go back to the program. Is there a command to add to tell it to close itself when its done launching the program? I have win98 if thats any help.
