Could use some help
LuckyForward
127
Does anyone know if there is a plug-in, or freeware/trialware program that allows users to save changes to PDF documents? I am in the process of filling out a job application and would like to save my progress and be able to transport the file w/changes, but Adobe Acro Reader won't allow saved alterations. The full version of Acrobat is too freaking expensive to justify purchasing for something as elementary as saving a document. Thanks
Kntx
2,270
The whole point of acrobat READER is to only be able to READ files :)
You need the full version to edit/create files. That is unless there is some open source/freeware alternative.
Mitzi
3,775
Open Office (freeware) will let you create PDFs, not too sure if you can open and edit an existing PDF with it though..not surething I've ever tried.
