klandingham
Hello,
I've inherited an old HP Pavilion 7955 that I'd like to use as an extra machine. It originally came with a 1.5 GHz Pentium 4 and a single 256 MB DIMM memory module (MB has 3 DIMM slots.) When I received it, all three memory slots had 256 MB sticks, so it was running with 768 MB.
From what I've gathered, the motherboard in this machine is an ASUS P4B-LA (Amazon) and specs at HP state that its max memory is 1.5 GB (which I assume means 3x512 MB)
I'm planning on putting a 2.4 GHz P4 in it, but my first step is to max the memory.
So, I bought 3 512 MB DIMM modules (PC133, unbuffered).
I removed the existing 256 MB modules and installed the 512's. The machine seems to pass POST (takes a noticeably longer time) then begins to boot the OS (Windows XP) but within a few seconds of boot loading it does a hard reboot.
If I remove any one of the 512 DIMMs (putting it at 1 GB) then it seems to boot and run normally, and Windows seems to see 1 GB properly.
I explored the BIOS settings but as this is a pretty old box, the BIOS doesn't have any settings at all for memory (that I could find.)
It seems that, according to the specs, 1.5 GB should work. Could my problem be inadequate power supply?
Thanks!
Thanks!
