- May 9, 2005
- 3,850
- 7
- 76
Last month or so I been getting random resets on computer. Did not think anything of it, now they started happened more when playing games. Guild wars 2 for example it would just randomly reset every 10-20min, then when back in win7 would have that "check for errors message cause bluescreen".
I ran MSI Afterburner with default fan speed , the 2 GTX 580s are default settings. Temps on one card would reach 85c and the other bottom one 76c. That is about when it resets. Idle they are 65c/59c (that seems high) I manually put fan at %70 and it kept it around 82c for about a hour and no reset. I know they are rated close to 100c.
The reason I suspect temps is I also had case cover off for most of the night playing Gw2 and not a single reset. Only this morning after I put cover back on.
Is it worth replacing the fan unit? Very odd never had a problem until recently. I know original fans on it from purchase about a year ago. They look dirty or anything.
