Could a PCI-E 16x 2.0 card work in a 1.0 PCI-E slot? and would the performance decrease if it could?
MraK
417
I have parted ways with my old rig (see sig) to my sister and have decided to get her 2 9800GTX+s for SLI, since it will be released in a week or so and noticed that they are 2.0 slot cards and that the motherboard, the card will be used on, is a 680i board that has 1.0 slots.
Could a 2.0 card work on a 1.0 slot? and if so, would the performance decrease do to the limit of the 1.0 slot, since the cards are 2.0 required?
I know, it may sound like a noob question but I'm just not very familiar with this kind of thing and I dont want to waste my cash on something that may not work with this computer.
Thanks in Advance:)
JPB
4,064
89
Thanks in Advance:)
Yup
MraK
417
k, so since they could work, would the card lose its %100 performance due to the slot being a 1.0 slot, since the card is 2.0?
ViRGE
Elite Member, Moderator Emeritus
167
No. There is a potential to lose performance, but it should not be severe and it will depend on the game.
Hajpoj
288
Considering no one has yet to maximize performance from PCI-E 1.0 yet...it just isn't possible at this point in time. All that 2.0 means is that they now have future headroom, or more "wiggle room" when developing tech to prevent hitting a wall. Hell they just maxed out AGP only recently!(if even) :roll:
Using this logic and following the trends, 1.0 shouldn't be a problem for future upgrades for a good while. <--If anyone has anything venerable to the contrary, please speak up!
taltamir
13,576
not true hajpoj.
there are many tests out there that show performance decrease. It would not be critical though.
Hajpoj
288
I mean it's not like it's going to be a deciding factor with the next gen of vid cards, And I would presume the performance hit would only be noticed if the rest of your specs were maxed that would allow a GPU bottleneck.
Hell; with 2 8800GT's SLI on a P5N-e SLI 1.0 board, I'm still CPU bound w/ an E8400@ 4.0ghz
Oblivion 1920x1200 with a boat load of mods.
taltamir
13,576
on a full 16x pcie v1 vs v2... then no it is not a deciding factor... but going down further (such as 8x or 4x CF operation and such) or using AGP for such a modern card does make the performance drop unacceptable.
You were just exaggerating too much.
And yea CPU bound is a serious problem, I recently did some serious testing showing that I am completely CPU bound (at low FPS) on Mass Effect with an E8400 @ 3.6ghz
Hajpoj
288
Mass Effect is HORRIBLY optimized for pc; since it's a port, you get "emulation-scaling" performance(basically your CPU is your daddy here).
